How to Drill and Tap T-56 salve?
Guest GM-7 Rocket
Guest GM-7 Rocket
I'm in the prosses of changing mt T-5 for a T-56 in my
84 RX-7 but I ran in to the problem of not getting the clutch line
and not wanting to buy a $184 master/slave and line set-up from GM.
I just bought a 1" wilwood master (which is requiered for my set-up)
and now need to connected it to this PITA slave. I have heard
that some have drilled and taped them with gret sucsess .
so I'm here to ask: What size tool do I need and where do can I find them
and also instruction or hits would be helpful too.
Also anyone had a custom line made buy a local hose shop for a direct fit?
I have a company named Hufca Inc that make custom braided hoses but I was wondering about price.
Thanks, JR
Guest GM-7 Rocket
you can get a quick disconnect line from Mcleod for around 70 bucks, -4 an on the other side. easy, and you dont have to mess with your slave.
Well that sounds nice but I'm trying to reframe from spending $70 on a part that’s not even 2in^3 big. my budget is stretch enough as it is. I could get two more slave and have 3 shots at it for $70 .
Anyone know where to get a fitting like the one in the pictures?
Any more help?
Thanks, JR
Guest GM-7 Rocket
Hey I think I found my CURE :eek:!!!!!
These look like they work and there cheaper then $70.
http://www.fortesparts.com/specials.cfm
GM 84-92 master slave stainless steel fitting
Description: This -4 stainless steel fitting is made to replace the OEM plastic lines on 84up GM clutch pressure line.
Installation Notes: These fittings fit many GM hydraulic pressure lines like in many trucks..
Special
$35.00
they look right enough :D guess all give it a shot and buy them tomorrow.
unless some one say no by then.
let me know, JR
Guest GM-7 Rocket
Ok it now accurse to me that I did say the I don't have the fitting that goes into the slave. I thought you could drill and tap the SLAVE it self.
The wilwood master comes with a 3/8 outline size
But any way I think I got it down now:
GM 84-92 master slave stainless steel fitting $35 + shipping http://www.fortesparts.com/specials.cfm
A 3/8 to 1/4 Coilhose Hex Reducer fitting (an-4 is 1/4" right?)
from home depot $1
1/4 hard line 30" $7
from napa
Stainless Steel Braided Line female an-4 fittings
91031842-4 12" Brake Line, Straight AN4 EA $9.95 + shipping
http://www.speedwaymotors.com/xq/aspx/dept_id.13/display_id.1992/qx/product.htm
Anyone know where I can get a shorter SS line like 8" or 10".
Thanks, JR
But was I right? an an-3 fitting is a 3/16" fitting and a an-4 fitting is 1/4" fitting right?
Thanks, JR
Well, yes and no.
An an-3 fitting can be used with 3/16 hardline and an an-4 used with 1/4 hardline.
But the fitting itself has a different angle (37°) whereas standard fittings are 45°. You can't put an AN fitting on a coupling made for a standard fitting. You also need a different flaring tool for AN vs. standard fittings (37° vs. 45°)
Not sure which question you are asking.
