260ZRED Posted October 25, 2006 Share Posted October 25, 2006 I want to be able to datalog 4 sensors: 2 temperatures - a)1 before intercooler & 1 after and 2 pressures - a) 1 before ic & 1 after This is to test the IC efficiency. My current running MS setup already has: temp ( and pressure ( as the input sensors. How can I add two more? (the temp a and pressure a) I dont need to MS to base calculations off of them, just to display and datalog them vs RPM. For the temperature, I would need to buy a duplicate of the GM air temp sensor, correct? For the pressure, how would I go about that? Can someone point me in the right direction here? Any and all advice would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 25, 2006 Share Posted October 25, 2006 MS Forum has some stuff on writing code for sensor circuits... There may be another method... Quote Link to comment Share on other sites More sharing options...
mobythevan Posted October 27, 2006 Share Posted October 27, 2006 I have always wanted a fuel pressure sensor wired in to be datalogged. I will be interested if you get something up and running. I haven't had time to look into it. Quote Link to comment Share on other sites More sharing options...
