weber dgv info
gjc5500
I have searched around on here and on google to find some info about them. i found info for the tripples but not for the twin dgv. does anyone know where i can get some information on the weber dgv twin 2barrel downdrafts?
I mostly want to know CFM and jetting info.
thx in advance
  • 1 month later...
i used to install these years ago-if you are really serious about set up the way to go is to get some kind of wide band a/f gauge system installed -you will use this on any engine you install in the car.i use innovate motor sports set up-thier website is very educational.73 240 and 74 260 had crappy flat top su's.goto twm website-i think they make a efi throttle body-injector to go on su manifold.also check distributor function-total advance curve.alot of old z's have locked up advance from worn parts.
