The age old battel
fast300zx
ok well i had the car running the other day and it ran a little rough no big so that night put a good battery in it and it wont start. here are some pics of wires laying around can yall give me an idea and help me out a bit.
thanks
the yellow wire thought that is were it goes.
looks to be a battery connection.
Black and yellow wire attached tothe subframe but not connected.
thanks
  • Replies 45
OK the top wire looks to be in the right spot, but there should be 2 wires going to the a/c reciever drier there. (the part you have it connected to) The middle picture is one of the battery terminals, most likely the positive as the negative should not reach. The black with yellow tracer is the ground wire and should be connected by the bracket to the frame rail. To make sure that the wores are correct, follow them to where thay go. If it goes directly to the starter = positive, if it goes to the block/bellhousing bolt = negative. If it still doesnt start check fuseable links right above the battery on the passenger side.
