new vs old nissan headgasket
racerx260
I rebuilt the turbo engine in my 260 about 2 months agao and used a nissan gasket . it had peal off plastic and was tackey to the touch. I am now rebuilding the engine in a 83 turbo I bought and ordered a nissan gasket. This one is dry. The part no. on the old one ended on 910 and a newer sticker was put on the box that ended in 911. The new gasket ends in 911.Do I put this on dry like a felpro or do I need to spray it with copp er or something?:confused:
I've never seen a Nissan OEM gasket that was sicky. All the ones I've used have been dry. Maybe you got one from a different batch made by a different OEM.
You can use the gasket dry, but if you have some copper spray handy, go ahead an put a couple coats on, it can't hurt.
I use copper spray on new OEM head and exhaust gaskets. In fact, I have reused OEM exhaust gaskets by appying 3 coats of copper spray. On NISMO metal gaskets I only use copper spray on the second or third use (never tried to reuse one 4 times).
I use the Permatex copper spray:
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_sealants/auto_Permatex_Copper_Spray-A-Gasket_Hi-Temp_Adhesive_Sealant.htm
You can get it at most auto parts stores.
It mainly improves the sealing capability. Yea, it is sticky, but that actually makes it harder to get the head on, and aligned.
I can see how this is important for a turbo motor running big boost. What about for a NA motor? I've not had any issues with sealing running the felpro gasket on a clean head and block, but maybe I was just lucky?
I hope I'm not sounding argumentative, I'm just curious about the benefits of copper spray. I've seen many people talk about it, but no one was ever able to really atriculate why they used it.
