racerx260 Posted November 9, 2006 Share Posted November 9, 2006 Help! I have A 83 TURBO MOTOR AND ECU IN A 260. hAS BEEN TROUBLE FREE FOR A YEAR . NOW ON THE WAY TO WORK IT WILL NOT IDLE. rUNS GREAT ABOVE IDLE .CHANGED OUT THE FOLLOWING , FUEL REGULATOR , AIR FLOW METER, HEAD TEMP SENDER, COIL AND IGNITER, ECU.CHECKED TIMING.ANY IDEAS?. ON THE TURBO I GUESS THE ECU CONTROLS THE THROTLE BODY TO CONTROL THE IDLE? COULD THERE BE SOMETHING THAT COULD GO WRONG WITH THE GIZMO THAT HAS THE HARNESS ATTACHED TO IT? HELP HELP. DAILY DRIVER. Quote Link to comment Share on other sites More sharing options...
racerx260 Posted November 10, 2006 Author Share Posted November 10, 2006 Changing The Tps On The Throtle Body Did Not Help. So I Adjusted The Stop Screw And Made It Idle That Way. Still Have No Idea Why A Stop Screw Set 23 Years Ago Would Have To Be Changed. Quote Link to comment Share on other sites More sharing options...
GrommitZ Posted November 10, 2006 Share Posted November 10, 2006 Sounds like your AAC valve stopped functioning. This valve bypasses air by the throttle. It looks similar to the egr valve but is located near the middle of the intake manifold. The ecu controls the Vacuum control modulator which in turn controls the AAC valve. I would guess that you have a vacuum leak from one of the small hoses that connect these systems. Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted November 10, 2006 Share Posted November 10, 2006 1. Don't type all in caps. 2. Why did you change all those parts without diagnosing your problem. Hell, you could probably bought a MS for the price of those parts. Quote Link to comment Share on other sites More sharing options...
racerx260 Posted December 10, 2006 Author Share Posted December 10, 2006 I have easy access to all those parts for free. a friend has a junk yard full of z cars.Well the mystry continues. After a week of driving with the stop screw adjusted to make it idle it reversed its self and went to idle at 1400 rpm. So I reversed the stop screw adjustment back to its original setting to get a 700 rpm idle.Three weeks later its still fine.If the acc valve stopped working it would stick open or closed.Closed it would make it run rich when hot but run fine when cold.If stuck open it would not want to idle well cold but should run fine hot. It would not start hot or cold until I turned the throtle stop screw on the throttle body from its stock setting. Quote Link to comment Share on other sites More sharing options...
