5 Star Rising Posted November 13, 2006 Share Posted November 13, 2006 I have a 75 280 standard Z. My drivers side door glass has been binding for a while when you try to roll it up or down and also rattling alot while driving. The other day I rolled it down and it would not roll up. I pulled apart my door panel to check it out. It looks like my window regulator may be tweaked and or weakend. I straightened the arms on the regulator abit but it did not help. Anyone have this problem with yours? What year cars have the same window regulator in them as my 75? (Junkyard bound). Any advice would help .... Thanks Rob Quote Link to comment Share on other sites More sharing options...
AK-Z Posted November 13, 2006 Share Posted November 13, 2006 there is the fuzzy strip that attaches the interior door panel that might need to be replaced, along with the outer lower weather seal. Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted November 13, 2006 Share Posted November 13, 2006 check the window roller-it mounts/clips under the outer stainless/rubber 'squeegee' strip at the base of the window. remove the strip carefully to see if the roller is there [near the mirror area]... if not, that could be your problem. additionally, the window channel fuzzy may have slid down and/or bunched in the channel Quote Link to comment Share on other sites More sharing options...
5 Star Rising Posted November 14, 2006 Author Share Posted November 14, 2006 Well I'm at work right now but, As far as I remember I did find a bunch of stuff at the bottom of the inside door. I remember finding a somewhat long felty roll or tube that was about 8 inches or so and also a bunch of debri that kind of looked like steel wool. would this be my roller and door fuzzy? Also there was a clip that mounted on the door metal under the stainless strip by the mirror. It was just clipped on the door with nothing attached to it. I was wondering what the purpose of that thing was.. Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted November 14, 2006 Share Posted November 14, 2006 the fuzzy stuff is probably what's left of your window channel fuzzy. the clip that's on the door under the window squegee is the remainder of your window roller. sounds like you need both; window channel fuzzy and window roller. fortunately, they are still available. Quote Link to comment Share on other sites More sharing options...
5 Star Rising Posted November 15, 2006 Author Share Posted November 15, 2006 Well Im not a big fan of using a ton of used stuff when restoring a car but today I hit the jackpot at the local Pick-N Pull (junkyard) here in Cali. I happened to be at the right place at the right time when the forklift guy dropped off a Cherry 76 280Z. It looked like the engine had a fire.But everything else was in great shape. I got a window regulator,rollers,fuzzys, not to mention all the other stuff I have been shopping for new like the 2 front and rear bumper guards,mint interior plastic pieces,original stock radio,console,the car was complete but not when I was done with it.lol Thanks for the help fellas.... I put my new window reg and rollers in tonight and it worked like a charm. Cheers Quote Link to comment Share on other sites More sharing options...
5 Star Rising Posted November 25, 2006 Author Share Posted November 25, 2006 Quote Link to comment Share on other sites More sharing options...
