383 240z Posted November 14, 2006 Share Posted November 14, 2006 OK here is set up. Fuel cell -8 feed line, TPI intake. MAX HP (I'm allowing for upgrades) is 500hp the major restriction is the -6 fitting on the stock fuel rail (both feed and return) In the end my 383 will be the engine with a larger EFI system (lingenfelter short runner system) but right now I just want to get this thing running so I put a borrowed 350 with a ZZ4 cam and my stock 350 TPI in. I'm needing an in line pump that I can fit the -8 lines to I can make the inlet side of the pump work with rubber hose if I change the fitting on the fuel cell. any ideas on what I can use that dont require I take out a 2nd on the house? Keith Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted November 14, 2006 Share Posted November 14, 2006 I used Walbro with the -8 fittings on both ends.... j. Quote Link to comment Share on other sites More sharing options...
Jaymz Posted November 14, 2006 Share Posted November 14, 2006 wow nice RB setup Quote Link to comment Share on other sites More sharing options...
