noisy relay board
DAT240Z
Are you running a PWM idle valve?
Some of the things this could be are rather bad. If it does this at idle, I would check the voltage on the fuel pump output to be sure it's not turning the fuel pump on and off. It wouldn't be so worrisome if this is the fast idle valve it's turning on and off.
i have version 2.2 board and that relay is the fidle relay.on version 2.2 you use the fidle circuit for either fidle control or spark control.since i use mine for spark the relay is removed and a jumper and pull-up resistor are in the relay sockit.is relay pulling in in relation to engine speed?like the relay clicking changes with rpms?the output also has to be configured on initial set-up with the software.my fidle circuit output wire goes directly to yellow wire on zxt power transistor /coil brackit.
