Mikelly's 76Z trackcar project...
So the plan is to start a Zcar trackcar project that would do everything well and safely...
699e.jpg?ph0RCfFBbpQ7hfy2
The Suspension:
ZFRacing Front Suspension control arms and TC Rods
Ground Control Camber plates upfront
Ground Control Coil Overs
Koni 8610 Struts.
QA1 250# front springs
Rear Arizona Zcar Control arms
Rear Arizona Zcar Camber plates
QA1 275# springs
Front Suspension Technique 1 1/8th sway bar
Rear 5/8th solid adjustable rear swaybar
Polyurethane Bushings on the steering rack, swaybar bushings, and inner control arms
Brakes:
Front Mustang Cobra Rotors and Calipers
Custom Jamie Tayler front Aluminum hubs
Braded Lines
Rear Z06 Calipers and 1985 Turbo300ZX Rear rotors
Five lug stub axles
ZX brake mastercylinder
Wilwood proportioning valve and Park-loc
Differential:
Q45 Differential
Custom Q45 axles from Speedway Engineering
Transmission:
TKO600 W/Roadrace gearing
Steeda Shifter
Ford Motorsport Racing 31 spline Yoke
McLeod SFI Bellhousing
CAT SFI Flywheel
Centerforce Clutch Kit
Tilton Hydraulic Release Bearing kit
Tilton 7/8th Master Cylinder
Motor:
4 Bolt Bowtie Block
Eagle H-beam Rods
Weisco Forged Pistons
Scat 9000 Crank
Cloyes True Roller Chain
Roller Valve train
Roller Tip Pushrods
Isky Lifters
Isky Cam
Dart Aluminum Heads W/2.05/1.6 valves
Edelbrock Aluminum FI Intake
42# Injectors
Holley 1000CFM Throttlebody
Holley Commander 950 PCM
Fuel:
15Gallon Fuel Cell
Bosch Fuel Pump
Braded fuel line
Holley regulator and fuelrails
Safety:
Driver - Kirkey Intermediate Roadrace Seat
Passenger - Kirkey Intermediate speedway Seat
GForce Camlock 5 point Harnesses
Chassis Mods:
14 Point rollcage by Piper Motorsports
Pete Paraskas Frame rails
Body:
1976 280Z frame
Dodge Viper Silver Paint Body
Black Trim on flares, Bumpers, spoilers, Door handles, hood vents
Japanese ZG FLares
Motorsport Stage 3 Front Airdam
BRE Style Rear Deck Spoiler
Body mods are complete and the car is painted. Chassis Mods are completed. Motor and trans are installed. Differential is installed but front mount needs made and the driveshaft needs completed. Suspension and brakes are almost completely done. Then I'll finish the electrical wiring and mount the dash, seats and harnesses... Still no decision on wheels yet.
Pictures can be seen here: http://photos.yahoo.com/dat74z and look in the "mikes painted Zcar project" folder...
Mike
