need help on side pipes exhaust
MY77Z
hi guys
i have a question since im installin a 302 on my 77 280Z, was thinkin about this.....
is it possible to install side exhaust on the 302/280Z...??? like the ones on a FACTORY FIVE MK3 ROADSTER ???? the Z will look great with side pipes i think.....
http://parts.factoryfive.com/newcatalog/engineex/sidepipe.htm
this is the link for the side pipe...
your opinions/comments are needed here :icon10:
thanks
Ali
I think side pipes would be awesome, but check your state laws first. NC doesn't have all the restrictions most states do, but they do have a clause that says only vehicles with side pipes as a factory option are allowed to have them. Also those particular pipes look like they require either a special adapter or header to install them properly and the Z's sometimes have a hard time with certain headers.
EDIT: Never mind, I see you're in kuwait. My bad.
There is a bunch of threads on side pipes already in the Exhaust section.
I am going this route but most guys who bought these side pipes found out they are way too restrictive. The inner diameter of the internal pipe is way too small. Cozy Cole did a big write-up on his and
Do a search and check these threads out.
http://forums.hybridz.org/showthread.php?t=90639&highlight=side+exhaust+install
http://forums.hybridz.org/showthread.php?t=110202&highlight=Patriot+side+pipes
http://forums.hybridz.org/showthread.php?t=110321&highlight=Patriot+side+pipes
http://forums.hybridz.org/showthread.php?t=115813&highlight=Patriot+side+pipes
I am going to go the same route as rytherwr/Wayne and have them made from glasspacks.
http://forums.hybridz.org/showthread.php?t=116374
Greg
  • 4 weeks later...
I've had sidepipes on my Z for quite a while now. I don't have big hp but it looks and sound good. only downside is that you and your passenger might get your cavs scorched while getting out of the car( every pass I had has gotten burnt but me even though I told them to be careful haha). I used to have white pipes with sheilds but didn't look nearly as cool as the crome ones. Good luck
