clutch problem
bens1088
i got a new clutch and when i floor it while driving the engine revs up really high like i have the clutch in but then when i let go it drops back down while the car isnt really going any faster. it seems like the clutch is slipping. it smells like burnt clutch when i stop too. whats your call?
Didn't have your flywheel surfaced when you did the clutch did you?
Was going to say the same + some clutch discs have very little offset to one side, if you put the disc upside down, it could prvent it from making complete contact with the flywheel.
Most of clutches though, are very evident as for the offset and if you put it upside down things will just not work and in one particular case, (susuki sidekick) I finished the job started by someone else, the guy had put the disk the wrong way and when I stepped on the clutch the first time, the damn fork just popped out of it's socket and I had to do it all over again.
