does 240z dash fit into a 280z?
VinhZXT
I've not compared the direct mounting points but they appear to be the same, or course the wireharness and gauge mounts are different and the console has to match the dash, and the 240 is set up to have the fuse box unsed the ashtray where as the 280 has the fuse panel in the passanger kick panel
About 20 years ago put a 77 280z dash in a 73 240z and had no problems with that and it mounted right in. I would assume it would go the other direction also I would assume it would be the same for the 260Z. I did this because I wanted to have an AC dash in the 240Z and I had a 77 parts car with a clean dash with the AC ducts. The fun part was the installation of the rest of the AC system going from the 280 to the 240. Good luck.
Thanks everyone for the replies. I am going to buy a 240Z with a perfect dash. I need to put this dash into my 77 280Z project car.
Careless,
Maybe we can swap since the 240Z is a bit closer to the 260Z.
I am buying the 240Z regardless.
Vinh
