Dp351zcar Posted December 14, 2001 Share Posted December 14, 2001 Is you z powered by a 455? If it is please post some pictures of it, post some even its not it's good to see other z's. Don Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 14, 2001 Share Posted December 14, 2001 I finally took the car to the muffler shop to get the duels put in. I can not believe how sensitive the breaks are. It has the Toyota upgrade on the front, earls SS lines from front to back, and a larger master cylinder. The darn things stops better then my Durango! Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted December 15, 2001 Share Posted December 15, 2001 rickeybell, I'm VERY glad your car stops better than your truck (I can see a Z passing a durango under braking in the Craftsman truck series now) Would love to see some pics as well. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted December 15, 2001 Share Posted December 15, 2001 Ross, you slay me. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 17, 2001 Share Posted December 17, 2001 I will be glad to post some crude pics of the install. It is up on the rack at the muffler shop right now. When I can borrow a camera, I will do a simple site on it. I did an install similar to the JTR setback installation. I set the engine back so far that the Distributor is about 1" from the firewall. The harmonic balancer is a inch forward of the cross-member behind the steering rack, so the engine weight is behind the cross-member. I was hoping for a lot of the weight toward the rear end. The install wasn't that bad. The main thing I wish I did not do was weld the rear end, and remove the A/C. But, we learn from our mistakes. I am trying to quiet the exhaust enough to make an awesome street sleeper . Here is a list of the current mods: Block: Stock Pontiac 455 Bored .030" over to a 462 Decked to 0.00" Line Honed and ARP Studded Rotating Assy: Stock crank cut .010" Stock Rods shot peaned and manufuxed, ARP bolts TRW Forged Pistons with lightweight pins Chrome molly rings Balanced Cam: Crane 272 camshaft Rodes variable rate lifters Harland Sharp 1.65 roller rockers Double roller timing chain Head: Pontiac 6x off a 400 2.11/1.66 SS Valves Crane springs and retainers Pocket ported and exhaust ported Port Matched to exhaust and intake. Head Studs 9.5:1 compression Intake: Eldebrock Torker II Eldebrock 750 Carb Ignition: Mallory Unilight Distributor MSD 8.5 Wires 300+ Ignition box and coil Transmission: TH-350 B&M Transpack Shift Kit TCI 2450 Stall Hurst Promatic Shifter sunk into the trans tunnel Brakes: 15/16 Master Cylinder Rear Proportioning Valve B&M Line Lock Earls SS lines replaced most the hard lines and rubber too Toyota Upgrade Bump steer mod JTR rear perch relocation Electrical: Ripped most out and redid. Headlight relays 90/100 watt Headlamps Added Interior lights under the dash. Added Auto Meter UltraLight Gauges Wheels: Still thinking!!! Probably Centerline Aztec Wheels 16x9.5 rear 16x7 front Future CV axle or R230 upgrade Plenty of bodywork!!!!!! Quote Link to comment Share on other sites More sharing options...
