Forcefed Z Posted January 10, 2007 Share Posted January 10, 2007 I sent my p90 to get flow tested......just wondering if anyone knows what they typically do stock, and what I can expect after its been ported....assuming its been done properly? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted January 11, 2007 Share Posted January 11, 2007 Heres my porting and stock numbers, and percentage increase. I used STOCK valves so keep that in mind. Quote Link to comment Share on other sites More sharing options...
Forcefed Z Posted January 11, 2007 Author Share Posted January 11, 2007 So then I should hopefully expect to see those # from my local shop.. ...I was thinking of going oversized valve as well, if I can find some bigger ones that will work in time. Havent done too much research on the benefits of the big valves tho. Trying to dig around on the site and see what I can turn up, or somebody running a similar setup. Quote Link to comment Share on other sites More sharing options...
drzed Posted January 11, 2007 Share Posted January 11, 2007 What shop are you using? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted January 11, 2007 Share Posted January 11, 2007 Yea, Bigger valves=less port velocity, and port velocity is VERY important, so keep that in mind. Quote Link to comment Share on other sites More sharing options...
Forcefed Z Posted January 11, 2007 Author Share Posted January 11, 2007 This head is for a turbo car, so does the port velosity matter that much or do I want as much air as possible getting in there.....also have a cam, but the specs are unknown..Looking for big #'s hopefully... Quote Link to comment Share on other sites More sharing options...
Forcefed Z Posted January 11, 2007 Author Share Posted January 11, 2007 What shop are you using? I was thinking Kersley in Langley city...seeing how its a block away from my shop, might be worth a shot... ...And I was trying to call you a while back, but the pager # I had no longer worked....I was looking for a head, but just ended up using one from another motor around the shop Quote Link to comment Share on other sites More sharing options...
drzed Posted January 11, 2007 Share Posted January 11, 2007 I don't know anything about them but let me know how it works out. How much does it cost (if you don't mind me asking)? I PM'd you with a new contact number. Quote Link to comment Share on other sites More sharing options...
SHADY280 Posted January 13, 2007 Share Posted January 13, 2007 hey whats kersley cost for a full port/ flowbench? zoltan is the local guy in abbotsford, but extemely costly, but he knows his stuff. Quote Link to comment Share on other sites More sharing options...
Forcefed Z Posted January 14, 2007 Author Share Posted January 14, 2007 the head is still at the machine shop...ill let you knopw what it comes back....mabe even see you out at the track. Quote Link to comment Share on other sites More sharing options...
