Cams for the VG30DET
260DET
These are the specs for the billet cams that Crow have suggested, any comments on what sort of performance they are likely to deliver? I know SFA about cams.
MODEL TYPE VG30 DET QUAD CAM V/6
---------------------------CROW COMPUTER CARD----------------------------
| PART NUMBER 1396 Date 16-JAN-07 |
| Cam type: Bucket Hydraulic type OHC |
| Advance Ground on Cam: 1 Lobe separation: 114 |
| .050 VALVE TIMING |
| Inlet opens: 5 BTDC Closes: 51 ABDC .050 Duration: 237 |
| Exhaust Opens: 53 BBDC Closes: 3 ATDC .050 Duration: 237 |
| ADVERTISED VALVE TIMING |
| Inlet opens: 28 BTDC Closes: 74 ABDC ADV Duration: 282 |
| Exhaust Opens: 76 BBDC Closes: 26 ATDC ADV Duration: 282 |
| Inlet lobe lift at TDC on the over lap: |
| Valve lift Inlet: .3578 Inlet Rocker Ratio: 1.00 |
| Valve lift Exhaust: .3577 Exhaust Rocker Ratio: 1.00 |
| RECOMENDED VALVE TRAIN COMPONENTS Kit Number: |
| Valve Springs: Spring height: Collets: |
| Retainers: Pushrod: Lifters: |
| H/D Timing Set: |
