she RUNS!! but not without issue i am afraid
jimbo5670
Thank god for this board, the car FINALLY runs, the day before I had to go back to school of course, hah. Running is a term I am taking rather liberally though, it seems to be wayyyyyy rich, and I was trying to figure out why. Here is what I am running.
72 240z
82 L28ET
MS 2.2 running fuel only
The tune from the Moby FAQ
Stock turbo
Stock boost
No I/C yet
Stock injectors
No resisters on the INJ grounds
Timing is set for 10degrees at idle, and coming up to 13 at 3000 rpm, not an ideal situation I know, but it is only a temporary solution
The symptoms I am getting are
Popping under acceleration
The car has “no ballsâ€
Hard as s*** to start
Thanks,
Matt
  jimbo5670 said:
but rich enough that the car would barely run and start at 33 psi of fuel pressure?
pull your fuel pump fuse and burn all the gas thats still in there by cranking and trying to get it to start a couple of times, and clean off your spark plug electrodes after that.
if it's been flooded or rich, you probably have a lot of deposits all over everything in there, which is making it hard to start.
then lean out your map by 10% increments, and try again.
