csz Posted January 29, 2007 Share Posted January 29, 2007 I just got my cablex Fri. late evening. Does anyone running a t56 with a cablex know the number of teeth on the exciter gear? I do not even know what the exciter gear is! Thanks for any input. Quote Link to comment Share on other sites More sharing options...
m1noel Posted January 29, 2007 Share Posted January 29, 2007 I cant remember either, it was either 17, or 40. I set mine up one way and it was way off so I went with the other, then went out with my GPS and found it was 8% off so I just used their numbers adjusted the 8% changed the switches and now it is on exactly. Only took me 2 runs down the road to make it work. What's your gear ratio and tire size? Mike Quote Link to comment Share on other sites More sharing options...
csz Posted January 29, 2007 Author Share Posted January 29, 2007 Thanks for the reply. I run 255/45/17 rear tire with a 4.38:1 lsd. Quote Link to comment Share on other sites More sharing options...
m1noel Posted January 29, 2007 Share Posted January 29, 2007 Yeah, thats way different than my setup but it should be easy to figure out. I really think it was 17 though. And make sure you hook it up directly to the VSS, not out of the ECM. I found out that won't work. MIke Quote Link to comment Share on other sites More sharing options...
csz Posted January 29, 2007 Author Share Posted January 29, 2007 Thanks for your time. I will install sometime this week along with a air fuel meter while the cars on jack stands. Quote Link to comment Share on other sites More sharing options...
m1noel Posted January 29, 2007 Share Posted January 29, 2007 So, I get a CableX figure of 57705. Try 58800 so switches 3,6,10, and 11 should be on. And make sure #12 is off. That should get you in the ball park. Quote Link to comment Share on other sites More sharing options...
csz Posted January 29, 2007 Author Share Posted January 29, 2007 Close to what I fig. Thanks again. It will be nice to have a speedo. The car is loud, I don't need to be speeding! Quote Link to comment Share on other sites More sharing options...
csz Posted February 19, 2007 Author Share Posted February 19, 2007 m1noel you nailed the cablex setting. I didnot have to adjust it at all acording to my wife's gps. Thanks again for your help. Know if you can straight out a demon carb! Quote Link to comment Share on other sites More sharing options...
m1noel Posted February 19, 2007 Share Posted February 19, 2007 Glad you got it going, sorry, I cant help with the carb. Mike Quote Link to comment Share on other sites More sharing options...
