big-phil Posted February 3, 2007 Share Posted February 3, 2007 I set the high boost to 16 psi, and in 1st gear it hits 16!! before it would hit about 9 in 1st 12 in second then hit 16 in 3rd. 16 psi in 1st gear feels awesome!!! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 3, 2007 Share Posted February 3, 2007 Nice!! Phil why didnt you try the Megasquirt Boost Controller?! its costs $24 and it uses a boost map.. so depending on RPM you can select how much boost you want to run. Quote Link to comment Share on other sites More sharing options...
big-phil Posted February 3, 2007 Author Share Posted February 3, 2007 Nice!! Phil why didnt you try the Megasquirt Boost Controller?! its costs $24 and it uses a boost map.. so depending on RPM you can select how much boost you want to run. I did'nt really know much about it?? I paid $150 for the Profec, so that would have been a huge savings! did you get your car fixxed? Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 4, 2007 Share Posted February 4, 2007 yeh it was a bad HEI unit.. and I forgot to ground the base of the new HEI unit.. yes it had a ground wire, but I guess the base of the HEI needs to be grounded too! Let me find you a link for the boost control stuff... http://forums.turbobricks.com/showthread.php?p=925829 Walk through on how it works.. and install. Basically its a small "relay" with 3 wires... and it uses a fast acting valve. (boost control "kit") http://www.sparkandfuel.com/catalog/product_info.php?cPath=34&products_id=39 and ofcourse.. the MegaManual for the boost controller and how to tune http://www.msextra.com/manuals/MS_Extra_Hardware_Manual.htm#boost Quote Link to comment Share on other sites More sharing options...
NCchris Posted February 4, 2007 Share Posted February 4, 2007 Basically its a small "relay" with 3 wires... and it uses a fast acting valve. Could the "command valve" on the Holset HE351 be utilized as the "fast acting valve? All of this is very interesting, I just bought a Holset and a L28 turbo shortblock for my 260. TIA chris Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 4, 2007 Share Posted February 4, 2007 no.. the command valve adjusts the variable vain technology if I recall. but I dont know for sure.. worth a shot to do some research Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted February 4, 2007 Share Posted February 4, 2007 Phil - I assume that lil GReddy solenoid box is a plastic covering. So I would definitely recommend you move that somewhere else or it will be toast soon and melted. That's pretty close to the turbo and manifold. trust me on this, I used to have my external map sensor mounted on top of my intake manifold (shop mounted it there) and I knew it wasn't gonna last. Within a couple weeks it was completely warped, melted and ruined. So just a heads up, wouldn't want that money going to waste. If you can relocate it on the firewall or somewhere outta the way of heat or under the dash. Quote Link to comment Share on other sites More sharing options...
big-phil Posted February 4, 2007 Author Share Posted February 4, 2007 Phil - I assume that lil GReddy solenoid box is a plastic covering. So I would definitely recommend you move that somewhere else or it will be toast soon and melted. That's pretty close to the turbo and manifold. trust me on this, I used to have my external map sensor mounted on top of my intake manifold (shop mounted it there) and I knew it wasn't gonna last. Within a couple weeks it was completely warped, melted and ruined. So just a heads up, wouldn't want that money going to waste. If you can relocate it on the firewall or somewhere outta the way of heat or under the dash. Ooooo THANKS!!!! I didn't even think of that! Quote Link to comment Share on other sites More sharing options...
NCchris Posted February 4, 2007 Share Posted February 4, 2007 no.. the command valve adjusts the variable vain technology if I recall. but I dont know for sure.. worth a shot to do some research The Holset HE351 is just a later gen HY35. It does not have variable vane technology. The command valve is an electrical selenoid that operates a type of spool valve. It is located on the compressor housing and the wastegate can gets its signal from this valve. I have been researching quite a lot on the Holset site and various Cummins sites. The Holset site expounds on it's superior technology without telling exactly how it works. I will post my findings. chris Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 4, 2007 Share Posted February 4, 2007 wow.. nice to know! thanks Quote Link to comment Share on other sites More sharing options...
