Will they fit?
I'm looking for wheels for my 72 240 project. I am going to use all Arizona z suspension including coilovers 5-lug brake kit and the lower control arms and rear a-arms. I want to run 18x8 +20 fronts with 235-40-18 and 18x9 +40 rears with 265-35-18 . I need to know if the offset will clear. I have rolled the fender lips but no flares.
The AZC front hubs move the wheel out a little from stock, You can effectively use a higher offset wheel. I will be running 16x8 +38 in front and 16x8.5 +20 in the rear. I may need to run a 3-2mm front spacer. In the rear it just barely clears the strut. I will probably run a 5mm spacer to give a little extra room.
In a nutshell (look at me, I'm in a nutshell!) the fronts should fit just fine, the rears will need spacers.
So you think a +35 would be a better offset for the rear?
