Flywheel Torque specs-Which ones to use?
madkaw
I am mating a bwt-5 trans to a P-30 engine and I am using the Turbo flywheel that came with the trans. I noticed the torque values for the flywheels are different for different year cars. Are the torque values mated with the crank or the flywheel. The p-30 has 101 ftlbs values while the ZXT shows 80lbs,which one do I use??
I believe that they are generally mated to the fasteners. So, if you are using the flywheel bolts for the P-30, use the 101 lb-ft spec.
