nbesheer Posted March 6, 2007 Share Posted March 6, 2007 First off I bought the ss brake line kit from MSA and it has 6 hoses ? I'm guessing 1 for each wheel but what are the others for ? Anyways I replaced one brake line and then I noticed that the old one had a copper washer. Should I use that washer ? Get new ones ? Or just leave it off ? Quote Link to comment Share on other sites More sharing options...
nbesheer Posted March 6, 2007 Author Share Posted March 6, 2007 Actually I just found the extra two brake lines. so that leaves the copper washer Quote Link to comment Share on other sites More sharing options...
LineC Posted March 7, 2007 Share Posted March 7, 2007 copper washer goes on banjo bolts,, HOODIE HOO Quote Link to comment Share on other sites More sharing options...
hughdogz Posted March 7, 2007 Share Posted March 7, 2007 Hey, The fronts each require one. The rear calipers on a 280ZX requeres four lines. One "inner" one and one "outer" one for each side. So, altogether six. I just got the same setup from MSA, and they said I didn't need that copper crush washer for the brake lines, just for the clutch line. HTH, -Hugh Quote Link to comment Share on other sites More sharing options...
nbesheer Posted March 7, 2007 Author Share Posted March 7, 2007 In don't know why you need the copper washer for the clutch line because it doesn't even screw in all the way. Well anyways I put them on there just to be on the safe side. But in the process of doing the lines I figured I would do a tire rotation but on the last tire the lug lock key broke!!! So now I can't switch them or anything till I get a new key. damn! Quote Link to comment Share on other sites More sharing options...
