Racin_Jason Posted March 9, 2007 Share Posted March 9, 2007 I am about to finalize my pieced together fuel system. I originally tryed the upper vent tube on the top driver side for the return inlet but it doesnt flow freely. I am running my 3/8" feed from the drain plug hole. Where can I route my 3/8" return line into the stock 240z tank? Car is a carbed Chevy. Thanks much Jason Quote Link to comment Share on other sites More sharing options...
z-ya Posted March 9, 2007 Share Posted March 9, 2007 Run the return back into the original feed fitting on the 240Z tank. The return will work fine with a 5/16" barb at the tank (ran this way for years). Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted March 9, 2007 Author Share Posted March 9, 2007 z-ya said: Run the return back into the original feed fitting on the 240Z tank. The return will work fine with a 5/16" barb at the tank (ran this way for years). I can feed the return straight into the original 5/16" feed with no mods to the stock configuration? That would be pretty convenient if so. Thanks Jason Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted March 9, 2007 Share Posted March 9, 2007 Racin_Jason said: I can feed the return straight into the original 5/16" feed with no mods to the stock configuration? That would be pretty convenient if so. Thanks Jason Why wouldn't this work? It is just a tube going down into the tank. The other option is to get an AN6 bulkhead fitting and drilling one hole (with a unibit) in the stock tank near the current returns. That way you can open the sending unit to get the jam nut on. http://www.jegs.com/webapp/wcs/stores/servlet/product2_10001_10002_749420_-1 Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted March 9, 2007 Author Share Posted March 9, 2007 I asked because this is my first Z car and the stock fuel system was stripped off when I got the car. Therefore I have no idea if its merely an open tube or if there is an intank pump or.. If it is just a pickup tube then it sounds like I am in buisness. Quote Link to comment Share on other sites More sharing options...
z-ya Posted March 10, 2007 Share Posted March 10, 2007 It will work just fine, as I ran mine that way for years before I added a surge tank. Quote Link to comment Share on other sites More sharing options...
