What could be wrong?
Hey guys, I cant seem to get my engine to fire up and im not sure why. I know that im getting spark on my plugs. Also there is +12 voltage to the injectors and I have fuel pressure but it still wont work. Does anyone have any ideas on what could be wrong? It will also fire up if I spray fuel in the air intake but then die when that fuel is burnt. There is also no fuel coming out of the fuel return, im not sure if that is important or not. Any advice would be greatly appreciated.
Check to see if you have fuel pressure to the rails. Remember fuel injection regulators control the output not the input. They bleed off excess pressure not restrict input fuel pressure like carbureted systems. I like the mechanical guages that just use male pipe thread to attach to the rails. Simple, relatively cheap and they work.
By the way, you won't get fuel to the rails if you hook up the fuel lines to the wrong input/output.
Guest sbcperformance
check the fuel pressure regulator. prone to go out on gm's also it is about the cheapest part out of the injection system so I would definetly start there.
Don't feel so bad. I did the same thing a few days ago on my camaro. That's why I brought it up. The only reason I diagnosed mine right away is because I have a rail mounted fuel guage. I could hear the pump turn on yet there was no pressure. Little things like that help diagnose problems
