switching from an internal to external wastegate
That is a great write up by Austin. Here are a few other shots to give you a few more ideas. I did not dump the wastegate exhaust gases to the atmosphere, I recurculated it back in: Shown here Here is a shot of the external wastegate flange coming off of the stock manifold here.
The block off plate you speak of, you can purchese that with either a V-Band already welded on, as I did Here or just buy the plate and weld on as needed. I assume the hole you are refferring too on the compressor side is the reference port; you can reuse that, and connect that to the external waste gate.
