j_eremy Posted March 18, 2007 Share Posted March 18, 2007 Need some help with yr's I am going to the Junkyard next week to look for a set of heads, I dont know what years or make or model chevy vehicle I a can find a pair of big valve 350 heads on somthing like 2.02 1.60, also I am pulling the r&p cross member, pump hoses ect to convert my 81 over for the use of headers on my v8. thanks Jeremy. Quote Link to comment Share on other sites More sharing options...
lbhsbZ Posted March 19, 2007 Share Posted March 19, 2007 I don't think 202 heads came stock on anything but the old fuelie corvettes. Even most of the camelhumps came with 194 valves. If you'd like, I've got a relatively fresh set of 194 heads from a mid 70s 350. They have less than 20K on them since the valve job. I could give them to you for $50. I have a buddy coming up from San Diego this week, and I could send them back down with him if you'd like. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted March 19, 2007 Share Posted March 19, 2007 the best heads that your LIKELY to find in a salvage yard are the VORTEC HEADS off some trucks but youll need to upgrade the intake and get the rockers,and valve covers when you get the heads 12558062...98......350..........L31 Vortec, truck, 64cc chambers, 1.94/1.5, 170cc intake port http://www.mortec.com/castnum.htm http://www.classictruckshop.com/images/gmhead.gif http://www.crateenginedepot.com/store/Complete-Cast-Iron-Vortec-Cylinder-Head-Assembly-12558060-P752C0.aspx but ANY used head is some risk of being cracked or worn , LIKE MOST OF US YOUR BUDGET IS TIGHT! but a HUGE amount of your engines power potential comes from the HEADS, CAM and DISPLACEMENT so think about spending a good percentage of your budget on GOOD HEADS, you won,t be sorry in the long run! read thru all the stages and see what works http://www.rustpuppy.org/chp/Welcome.html http://store.summitracing.com/partdetail.asp?autofilter=1&part=TFS%2D30400001&N=700+115&autoview=sku Quote Link to comment Share on other sites More sharing options...
