SR20DET temp sensor
OK, I have been driving my car again for a while. I worked out the ECU issues by putting in a Power FC D-Jetro.
My question is where I can find a temperature sensor. I have the camaro radiator with a taurus fan. It cools fine, but when sitting in traffic, the car heats up. The fan does not kick on until the sensor reaches 200 degrees. The sensor is on the radiator. The guage which has a sensor on the block reads 218 before the fan kicks on. I dunno if the gauge is incorrect or if the block is 20 degrees hotter than the coolant temp. Either way, I would like to find a 3/8" NPT temperature sensor with one pole that kicks the fan on at 180 degrees instead of 200. Any suggestions?
