Racin_Jason Posted March 23, 2007 Share Posted March 23, 2007 So I am about to put my dash back into the car with some outsourced guages. I'd like to clarify they work now if possible. Whats the easiest way to test them out of the car? I hope I got the needle pointers put back on the speedo and tach correctly. I wouldn't want to have to pull this dash again! Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted March 26, 2007 Author Share Posted March 26, 2007 After more searching over the last couple days I have found...nothing bump! Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted March 27, 2007 Author Share Posted March 27, 2007 Im not going away BTT Quote Link to comment Share on other sites More sharing options...
jbk240z Posted March 27, 2007 Share Posted March 27, 2007 Maybe you can just set the dash temporarily in place. Then plug in the connectors, add temporary grounds where needed. Good luck. Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted March 29, 2007 Author Share Posted March 29, 2007 Unfortunately its not that easy. The car is apart and does not run. I dont even have a battery for it yet. Thanks for the idea though. Would be the way to do it on a running car. Jason Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted March 29, 2007 Share Posted March 29, 2007 The speedo you could test by hooking the speedo cable to a power drill. The tach could be tested by hooking it to another running car. A 280 tach should work with just about any car. Quote Link to comment Share on other sites More sharing options...
DCZ Posted March 29, 2007 Share Posted March 29, 2007 The oil pressure, water temperature and fuel level guages are basically ohm meters. Get a variable resistor (potentiometer) and connect that between ground and the sender input on the guage. Figure out which wires on the guage are +12V and Ground and hook them up. Resistor values of the various senders should be somewhere in the FSM so you should be able to tell how well the guages are calibrated. If you ground the sender input instead of using a resistor, most if not all of these guages should go full scale. *Disclaimer* I have not done this but that is how I would approach it. Quote Link to comment Share on other sites More sharing options...
