1FASTKINGCAB Posted April 1, 2007 Share Posted April 1, 2007 This was just mock up on a spare frame & fire wall Quote Link to comment Share on other sites More sharing options...
84Nissan300zx Posted April 1, 2007 Share Posted April 1, 2007 nice looks like alot of work. Quote Link to comment Share on other sites More sharing options...
nismopu Posted April 2, 2007 Share Posted April 2, 2007 you figured out what your gonna do about the tranny? or are you gonna use a 2wd v6 pickup tranny? my friend and I are starting this project this summer in a 4wd so its gonna be pretty crazy. how does the frame clearance look with the turbos on? cant wait to see more on this thing. peace. Quote Link to comment Share on other sites More sharing options...
1FASTKINGCAB Posted April 2, 2007 Author Share Posted April 2, 2007 I have a 2WD 5speed pickup already with a VG30E in it, so I'm gona do the swap into that. I only have two pass side TT manifolds, so I don't knwo the the drivers side will fix into the stock turbo location. The pass side fit verry good, but I'm going to make solid motor mounts because clearance in gereral is way tight. the driversside turbo will have to wait untill I get my hands on a TT Z32 drivers side manifold Quote Link to comment Share on other sites More sharing options...
nismopu Posted April 2, 2007 Share Posted April 2, 2007 i think we have one laying around here with a broken stud in it, as long as you can use it, im sure i could just ship it to ya. this project would seriously help my friend out because he is not optimistic of clearance. peace. Quote Link to comment Share on other sites More sharing options...
1FASTKINGCAB Posted April 2, 2007 Author Share Posted April 2, 2007 You have PM Quote Link to comment Share on other sites More sharing options...
Guest mini702 Posted April 26, 2007 Share Posted April 26, 2007 I'm doing the same conversion this summer but not turbo. Any pointers? Looks like everything will bolt in but am concerned about brake booster clearance. 2wd v6 chassis. Quote Link to comment Share on other sites More sharing options...
sweetride2go Posted January 31, 2008 Share Posted January 31, 2008 hows the progress on the vg-pickup??? Quote Link to comment Share on other sites More sharing options...
Zdaddy Posted March 6, 2008 Share Posted March 6, 2008 sweetride2go said: hows the progress on the vg-pickup??? +1 VGP wants to do a spotlight on you and your project(s) Quote Link to comment Share on other sites More sharing options...
Dj Hentai Posted July 10, 2009 Share Posted July 10, 2009 I'm doing the same swap as well, but my plan as far as mountings go is to use the Z's mounts and fabricate some sort of mount brackets on the frame to accept them. I was mainly worried about clearance with regards to the brake booster on the firewall what with the larger heads and wide intake mainfolds. I've got no inner fenders, and am building tube frame supports for the fenders them selves so I have tons of room to work where that's concerned. How goes the swap, any progress? Quote Link to comment Share on other sites More sharing options...
Dj Hentai Posted July 12, 2009 Share Posted July 12, 2009 2nd Q - Are the manifolds & turbos on the engine in your pics? I can't see to tell. I hung my engine in the bay yesterday and today I'll be removing the original hardbody frame provisions for the engine mounts as they hit the oil pan. It also seems like the turbo on the driver's side is going to be interfering with the steering shaft once it sits down where it needs to... Quote Link to comment Share on other sites More sharing options...
nismopu Posted July 12, 2009 Share Posted July 12, 2009 thats a 4x4 truck he was mocking this up into as well, that makes a huge difference in clearance. he hasnt been heard from in a while either. Quote Link to comment Share on other sites More sharing options...
1FASTKINGCAB Posted August 8, 2009 Author Share Posted August 8, 2009 The VG30DE-TT swap didn't go so good, when the going got tough I bought a Z32 and put the motor where it belonged. in reality I made to swap harder than it needed to be but WAY overbuilding the truck for the WHP a stock turbo VG30DE-TT would put down. My bigest mistake was moving the enging down 4" and back 6" it's a quite extensive swap. I really need to know what your working with and what parts you have. What year is your truck? What drive shaft is in your truck? (1PC or 2PC) What motor came in the truck? What trans do you have? i know you are going to need to modify a NA VG30 TRUCK oil pan to fit the TT motor, you will also need the truck oil pump pickup. You are also going to need a custom steering shaft or relocated turbos. also If you run the turbos is the stock location you will need 90-96 JDM TT down pipes to clear the trucks frame. and you need to use the Z32 starter and trans. Quote Link to comment Share on other sites More sharing options...
sweetride2go Posted August 11, 2009 Share Posted August 11, 2009 I was wondering about steering shaft clearances... It wouldn't be the first steering shaft I have made though, lol. I'm on version 3.0 on my Z right now. When I get to the point where I can set the engine in the engine bay, I will defiantly post pics. cheers ryan~ Quote Link to comment Share on other sites More sharing options...
