kvansic162 Posted April 1, 2007 Share Posted April 1, 2007 My TPS readings are closed:0 WOT:168 ...are those good values or do I need to adjust. I'm using a 240SX TPS . I read in the manual the WOT should be 178? Quote Link to comment Share on other sites More sharing options...
z-ya Posted April 1, 2007 Share Posted April 1, 2007 Those numbers are fine for a 240SX TB. The actual TPS determines the WOT number (or resistance). Even two identical 240SX TPS may have a different WOT number. Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 1, 2007 Share Posted April 1, 2007 should it always read "0" when closed? Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted April 1, 2007 Share Posted April 1, 2007 To check to see if it is "ok" - turn on the throttle position guage in megatune and make sure that it reads 0% without your foot off of the peddle. AS SOON as you start to put your foot down - the guage should start to increase. With your foot to the floor - the guage should read 100%. If it does all of this - you should be good. Quote Link to comment Share on other sites More sharing options...
kvansic162 Posted April 1, 2007 Author Share Posted April 1, 2007 Phil, what is the modification you are doing to the mega squirt on you tube? Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 1, 2007 Share Posted April 1, 2007 kvansic162 said: Phil, what is the modification you are doing to the mega squirt on you tube? I was showing what you have to do to it before you install it in the car, and also I replaced the vb921 that fires the coil. I thought mine went bad, but that was not it. It was the optical sensor in the distributor that went bad. Quote Link to comment Share on other sites More sharing options...
