Oil Restrictor/Turbo Feed Line - Will this kit work?
ktm
If you're using an L series, that is the right adapter...the 1/8" BSPT is for where the oil feed line hooks to the block. i.e..at the oil pressure sending unit port on the right side of the motor. It is threaded BSPT, NOT NPT, thus the adapter.
Hope it helps,
Warren
