Supercharger or Higher Flow Heads - Newbie Needs Advice
lilredZ
This is simply not true. While static compression certainly has an effect on efficiency, it's fuel and timing that will determine how efficient the combination will ultimately be- and how long the motor will take the abuse.
13:1 engines work great with nitrous oxide, and you can guarantee that the 13:1 engine will outperform the 8.0:1 engine, and by a huge margin- provided the tune is good. Even supercharged motors can operate in the 11:1 range very effectively- and there are many that do this in lieu of the old school thought of low compression with boost. Compression is a small factor in comparison to fuel and timing. The new stand alone engine management systems such as the F.A.S.T. system have made compression a non-factor, or at least minimal as compared to the fuel/timing curve.....
Did I miss something?
My comments were relative to his only wanting an addt'l 100 hp and that he would be running with mufflers.
He didnt come right out and say he wanted a streetable car but only wanting an addt'l 100 hp indicates he's wanting to run on pump gas and keep the car streetable.
You can not run an 13:1 streetable car with a supercharger or turbocharger on pump gas w/out serious and immedieate longevity issues.
Sure you could reach extremes but at the loss of streetability.
Yes you can run an 11:1 SCR engine (Normally Aspirated) as long as the tune is correct...as you said many modern mfg's are doing this now and have been for awhile. An 11:1 on up SCR with a power adder is Pro Racing territory. From my reading his initial inquirey - he isn't wanting to reach those heights.
My comments about his addt'l desired 100 hp was correct in that whichever decision he made, be it normally aspirated or power adder, he needs to tune accordingly.
Kevin,
(Yea,Still an Inliner)
Guest Gr8White
Kevin,
Hi Kevin,
I guess I could have been more specific, the only thing that I really diagreed on was your original statement of not being able to run a nitrous car effectively @ 13:1, with my contention being that nitrous oxide works very well at 13:1. You grouped nitrous and supercharging together, 2 totally different animals, wouldn't you agree? I've yet to see a streetable 13:1 car, naturally aspirated or otherwise!
