brake pads for 82-83 280ZX
Guest Will
I have a '75 V8 280Z with 82-83 ZX calipers. In a recent street encounter I found myself having to stop hard from ~120. I encountered quite noticeable, but not extreme, brake fade eek2.gif I knew those pads weren't worth a S***, but I didn't know they were that bad :rolleyes:
Anyway, what's a good brake pad for this caliper which is streetable, but can still stand the occassional hard stop from 120 without causing me to momentarily wonder if I should take the next exit?
"Anyway, what's a good brake pad for this caliper which is streetable, but can still stand the occassional hard stop"
KVR carbon fibre 'sport' compound, allowed me to stay sane till I completed my brake upgrade. ZERO fade even while I was boiling away fluid (in my experience at lapping days) was my experience. And incredibly friendly/flat rotor wear. A 510 owner bought my complete brake setup when I upgraded and he was stoked...pads/rotors were 2 yrs old and ~70% remaining on pads and rotors were flat and unturned (front and rear).
~$55 delivered to your door (I'm a distributor). Scottie used them with success as well with his Z calipers AIR.
i am running the same brakes as your car with the exeption of having 86zx rear calipers on my 510. i am using www.poterfield-brakes.com r4s compound they are a little pricey. but, the difference in stopping distances in my 510 were nothing short of amazing.
I bought a set from Ross C. for my 71 240z with stock brakes. I haven't been on the track yet but they have been great so far for spirited street use. No squeal, no fade, consistent predictable stopping power. 2thumbs.gif
Ross
I was about to purchase metal master pads for the 240z, but the KVR pads sound better. Do you have to heat up the KVR pads before they become effective? I am using stock pads now and they suck.
Miles
Originally posted by Miles:
Ross
Miles
Miles: KVR says they require zero warmup...in my experience & opinion they're a bit cold on 1st or 2nd stop and fine after that.....they just get better and better above normal temps as well. After the instructional days and events I've been at I just routinely tap my brakes anyhow to see they work each time I head out anyhow..... :D
Speed kills so brakes breathe life ;)
