Big Bore Throttle body
Guest Dashibhs2004
Guest Dashibhs2004
For those of you looking for a boot for that big bore throttle body and are having problems, marine wet exhaust hose. 2 3/4" inner diameter is what you would need for a 60mm throttle body. You can get many different sizes of hose but its one piece so if you wanted to go with a bigger tb you would have to wrap your airflow meter with black tape or somethin till it sealed.. at any rate hope that helps some of you needing ideas for intake pieces for the 240 sx throttle body.
  • 1 year later...
I was thinking of seranwrap, if I ever used mine.
Some time ago you had mentioned about volumes for the runners and stuff, and that made alot of sense to me.
Mabey some day, but it needs to match all the way into combution camber and out.
Still may use seranwrap and gorrilla tape;)
