Guest Dashibhs2004 Posted April 11, 2007 Share Posted April 11, 2007 Now I did some searching and didn't see my problem or maybe no one noticed what I noticed. My front brakes work perfectly you just have to get the pedal to them. For the rear brakes to grab you have to pump it three times and when you let off you lose all that pumping pressure. Here is the weird part. I took off my resivoir caps and watched my fluid as I was pumping, air was coming up through the rear fluid resivoir, and I never lost and fluid. Three or four large bubbles each time. I tried bleeding the whole system to no avail and manual adjustment did not work. Any ideas? the Master Cylinder and the Brake Booster are both new. Quote Link to comment Share on other sites More sharing options...
Daeron Posted April 11, 2007 Share Posted April 11, 2007 there is a brake forum, this is the engine forum Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted April 11, 2007 Share Posted April 11, 2007 You need a new MC Quote Link to comment Share on other sites More sharing options...
