piston height
a72z4me
In stock configuration, the pistons in a l28 engine are .007" under deck,according to lengine chart.I'm rebuilding mine now and have bored 1mm over,stock rods,87mm pistons,stock crank,.005" shaved off deck height.With those dimensions I should still be .002" under deck.Problem is I"m .012"-.013" over.My only guess is that I was given a piston with wrong pin height.My question now is can I proceed with the build with that piston height.
  • Administrators
Continue on with your build. You won’t have any issues. The Flat Top L-28 pistons pop up out of thebore .020”-.025”, and with a stock Nissan or Felpro head gasket, the squish with a matching head is then PERFECT! Though you wouldn’t want it any closer than that.
Your pistons will NOT contact the head or valves, (unless you don’t time the cam properly).
Hope that helps,
Paul
