Accurate Injection Posted April 16, 2007 Share Posted April 16, 2007 Anyone ever build a 7MGE 3.ltr bottom end with a 5MGE Head? I have several of these engines, but none have good 7mge heads! I know from looking at the heads it will not flow as well, but wonder what compression ratio, HP, and Torque numbers the combination might make? Here is an idea for ya or what we call "Runner Length Tuning" for the Normally Aspirated Guys! And Yes......... they would all need to be the same Length! 3 50mm ITB's has to flow better than 1 60mm right? Hahahaha! You can add 1", 2" or 3" on each end of the Extrudabody ITB's to tune the runner length or to work around some clearances in the engine compartment! This was a simple Machined Base Plate "With no fancy CNC work" to show what can be done with the Extrudabody Concept! Kevin Quote Link to comment Share on other sites More sharing options...
ARZ_ Posted April 18, 2007 Share Posted April 18, 2007 Check this guys site. http://www.driftmotion.com I think he is doing exactly that except trying to Turbo that block. His main objective is to increase displacement for a turbo motor. Quote Link to comment Share on other sites More sharing options...
Accurate Injection Posted April 18, 2007 Author Share Posted April 18, 2007 Thanks Fiddy! Kevin Quote Link to comment Share on other sites More sharing options...
76s30 Posted June 3, 2007 Share Posted June 3, 2007 back in japan in the day they made a 6mge before a the 7mge, it was just that a 7m bottom with a 5m top. the 5m heads flow quite well have a close look at one off an engine. nice combustion cambers, good radius's on the ports, big valves. a turbo 5m makes same hp lb for lb of boost as a 7m. but the torque curve is wayyyyyy different. I built a tt 6mge. I sold it just recently to a friend of mine that has a MKII supra, can't wait to see it in there man that sucker will go. Quote Link to comment Share on other sites More sharing options...
