Water leakage problem
Whenever it rains out, water will drip inside the car from underneath the dash only on the passenger side. We just had new weather stripping put on and this didn't solve the problem. Today when I was washing it, we used the hose to try and figure out where it was comming it. When we'd poor the water over the cowling on the passenger side, water would start to immediatley drip in underneath the dash. We toor all the carpet out on the passenger side to let it all dry out since the carpet got soaked. We cleaned all the dirt and debrit that has collected in there from over the years and the drain tubes seem to work fine. The small rubber drain hose underneath the dash is not cracked and looks fine. This leak cannot be seen when laying underneath the dash while water is being poored in the cowling because of the kick panels. We're thinking of maybe pooring a sealent that will harden into that cowling area to see if it will seel up any cracks. What kind of sealent would you recommend for this? Thanks!
