Getting a 100K mile LS1, what to check?
To the best of my knowledge compression checks do require that the engine be runable.
Dry is just putting the compression tester in the spark plug hole and cranking it over a couple of times.
Wet testing is the same, but you squirt a little bit of oil in the spark plug hole before running the test.
The difference between them typically is an indicator of piston ring problems, if the pressure on a cylinder comes up dramatically when wet.
