5 speed gasket sets
ezzzzzzz
There's only one gasket, or at least mine only came with one. It's the one that seals the input shaft cover thingy inside the bell housing. Silicone the front and rear housings to the center steel part, then there is a rear seal for the mainshaft. That's about it I think. You could make that gasket with some gasket paper, or just substitute silicone.
I have a rebuild kit for an early 280Z which includes the first motion shaft housing gasket. Since it was opened long ago I assumed the other gaskets had been misplaced. I'm a fan of Permtex hi-temp gray sealant and will use it at the case seams as Jon has suggested. Thanks again.
