SSflyer Posted April 24, 2007 Share Posted April 24, 2007 Four shops and $750 later, the whole problem was a vacuum leak. On the back of the LS1 intake manifold is a vacuum take-off port for the brake master cylinder and also for the vacuum pots under the dash. I mounted my proportioning valve right under the hood latch bracket, and in order to get the engine placed I had turned that take-off stem about 30 degrees to clear the proportioning valve. That little turn was enough to get the stem off its' seat and cause a vacuum leak. Sometimes it's the simplest things! Part two of this post is to get some opinions on a custom plate. Here's some choices that are still available in Arizona: LS1280Z LS1ZCAR 350RWHP 280ZCAR TKTMGNT WHUPDEM ONLY13S CERPRIZ SUDDEN SUDDENZ MYTSLOW NOTAVET MID13S HIGH12S NEVRA12 SLGBATE KLUGED HAULZ NOTBENT SQUIRLZ PWRMAD Which should it be, or do you have other ideas? Quote Link to comment Share on other sites More sharing options...
SteelToad Posted April 24, 2007 Share Posted April 24, 2007 Sryofzr Quote Link to comment Share on other sites More sharing options...
typhoone Posted April 24, 2007 Share Posted April 24, 2007 keepup toofast catchme byebye or one I saw the other day and laughed VERY hard about: midlife Quote Link to comment Share on other sites More sharing options...
SSflyer Posted April 24, 2007 Author Share Posted April 24, 2007 Midlife would be a real good choice, but it's already taken. So is Midlyfe. Dang! Quote Link to comment Share on other sites More sharing options...
