Guest psychrage Posted April 24, 2007 Share Posted April 24, 2007 Hi everyone, Couple quick questions on the EZ Wiring 21 circuit harness. Basically, these are made for GM cars, right? so would i need a GM ignition or any GM electrical parts? Also, is wiring the turn signal/headlight stalk easy? Thanks. Quote Link to comment Share on other sites More sharing options...
Sparky Posted April 24, 2007 Share Posted April 24, 2007 Hi everyone, Couple quick questions on the EZ Wiring 21 circuit harness. Basically, these are made for GM cars, right? so would i need a GM ignition or any GM electrical parts? Also, is wiring the turn signal/headlight stalk easy? Thanks. 1. No 2. Yes Quote Link to comment Share on other sites More sharing options...
Guest skipfl Posted May 2, 2007 Share Posted May 2, 2007 EZ Wiring is gm oriented, but always remember, all wiring is basiaclly the same you bring power from point A to point B and need enough wires to cover your application Quote Link to comment Share on other sites More sharing options...
Poundz9oh9 Posted May 2, 2007 Share Posted May 2, 2007 Dude, try searching. There's a STICKY thread with about 90% of the information you need for this, the other 10% can be found in the instructions for the wiring harness and/or related searches. Edit: Here ya go. I even did the work for you. http://forums.hybridz.org/showthread.php?t=94822&highlight=ez+wiring Oh, and welcome to HybridZ. Quote Link to comment Share on other sites More sharing options...
Guest skipfl Posted August 24, 2007 Share Posted August 24, 2007 EZ wiring can be used on any vehicle, except rear engine type. Their instructions, cover gm, ford and mopar. Quote Link to comment Share on other sites More sharing options...
