Anyone install SDS Fuel Only? Help
sfpar
Hi All,
Just finished installing the SDS and the car won't start. I have spark and fuel to the rail but the injectors do not seem to be receiving the signal to allow fuel. I have the green sds/coil wire hooked to neg. coil as prescribed but no luck. Anyone ever run across this?
FYI, I did take same green wire and tap it back and forth from + to - side of coil and could hear the injectors click.
Setup is 78z distributor/ignition
only change is MSD masterblaster II coil
82zturbo engine
