New Suspension
Guest Simon
Guest Simon
can some one please lead me in the right direction for some new Suspension , springs and shocks....brands..websites etc...i want to spend $AUS2000 or less. If possible.
for drifting and road / track racing - more racing than anything
Cheers,
Simon
Summit racing has Suspension Techniques bars and springs. $400 US for all. I would go with the Tokico non-adjustable struts if $ is tight, but I'm buying adjustable struts next time. Check out some of the other guys who sell coil over conversions. You could probably get parts from a Aussie supplier. (Do a search on google for 240Z turbo, guy down under named Simon, I believe, has a great site.)
$1400.00 US (don't know the Aussie conversion not including shipping to you) will get you camber plates, coil overs w/springs and Illumina Adjustable Tokicos on all 4 corners.
I would also suggest fabbing/buying a rear strut brace. Get 200lbs springs for the front and 250lbs for the rear as a starting point. I used 10" coils and didn't cut my struts.
For $300. more you can go Ground Control. I like their camber plate set-up better but you can make do with MSA.
Just my opinion.
Jon
Guest VertexZ
well $2000 should get you a fairly good setup:
for new springs & struts fitted on all 4 corners you are looking at about $800 maybe a little more....
a set of 4 Koni adjustables are worth about $1200 or so - they are top of the line stuff...
King Springs have a good reputation and should cost you under $300 for 4
Pedders are worth a look - www.pedders.com.au
hell of a lot cheaper that the Konis - i think about $600 for the Sports Ryder stuts (4)...probably a good mid range choice
You should also get all new bushes as well, preferablly urethane ones. Bigger sway bars might be worth a look also.
you should be able to get a good setup for well under 2k though
