Guest specialk198305 Posted May 13, 2007 Share Posted May 13, 2007 I have searched several forums to try and find motor mounts for the 350 chevy swap with no luck. does anyone know where i could buy some? or even any kind of info on the subject. thanks Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted May 13, 2007 Share Posted May 13, 2007 Search for user Alf, he's done a 350 SBC swap into a Z31. As to buy the mounts, I don't think anyone does sell them, so it will be a custom fabrication. A couple of users' have done it, but there isn't too much info out there, best of luck searching. Tyson Quote Link to comment Share on other sites More sharing options...
Syndicate Posted May 14, 2007 Share Posted May 14, 2007 If you have minor welding experience. I can ship you out a set of engine and trans mounts for your car. Up to you. Quote Link to comment Share on other sites More sharing options...
Alf Posted May 14, 2007 Share Posted May 14, 2007 If you have fabrication skills or know somebody that can help you that does, you shouldn't have that hard of a time doing the swap. Here are some links to help get you started. http://forums.hybridz.org/showthread.php?t=118962&highlight=z31+v8 http://forums.hybridz.org/showthread.php?t=116185&highlight=z31+v8 http://forums.hybridz.org/showthread.php?t=108065&highlight=z31+v8 Quote Link to comment Share on other sites More sharing options...
BigDaddyJC Posted May 14, 2007 Share Posted May 14, 2007 I have a SBC solid front engine mount I designed for use in hybrid conversions. I am having the first prototypes ran this week. The material is 3/16" steel plate with 1/2" bends along all perimeters for added strength. Its a solid mount that bolts to the front of the engine at 8 places. I have pdf. file of the drawing, or could possibly offer up a complete kit for the engine and turbo 350 auto tranny, once I get mine all installed and bolted up. Since this is a swap that there seems to be limited info. and parts available, I just decided to design some up myself. I'll post up some pics of the engine mounts and spacer once its done and go from there. As of yet, I still have to complete the first install before I offer up anything though for sure. My mount locates itself up onto the frame rails instead of down on the lower cradle. I am still debating on whether to make it a solid mount or use factory GM mounts. Quote Link to comment Share on other sites More sharing options...
Guest specialk198305 Posted May 14, 2007 Share Posted May 14, 2007 Thanks Guys for the info. Quote Link to comment Share on other sites More sharing options...
Guest specialk198305 Posted May 15, 2007 Share Posted May 15, 2007 Maybe im a little confused on the subject but after more searching it looks like people have used the stock ecm to control the basic engine control functions? Quote Link to comment Share on other sites More sharing options...
