Manual Shift for 4N71B trans?
TomoHawk
Thanks, I will call them sometime to see what they can do. I'm not exactly sure that a full-manual valve body is a good thing. Internet research suggests you could miss a shift & hurt your trans, but that goes for a manual shift trans too. This applid mainly to the early Mopar torqueflites.
The reason I thought the manual valve body would be cool is because B&M makes (or used to) an H-gated shifter for autos (Ford AOD?)
It might not be too good in a cruising Z with an O/D trans because you're not supposed to shift with the lockup on either.
thx
