Tony240ZT Posted June 5, 2002 Share Posted June 5, 2002 Does the heat shield that is on the side of the brake master cylinder in a 280Z bolt into the 240Z fairly easy? My turbo in the orange car is heating up my resivours pretty good, and I think I can notice the brake fade after driving around for some time on a hot day. May have to do with pads, and such, but there's no doubt that the master cylinder is much warmer than it should be. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted June 5, 2002 Share Posted June 5, 2002 Tony, might want to consider 280Z hood vents or a 280ZXT vent located over the turbo. You might be better off letting the heat rise and vent out than trying to protect something from the heat trapped underhood. Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 5, 2002 Share Posted June 5, 2002 I kind of agree with Scottie. I would do both the heat shield and the hood vents. You could score a 280 hood, but I like the later vents better. I'm planning on scoring an 82-83 ZX hood and cutting the vents out and welding into my hood. I've got a parts 280 and I've been eyeballing the same shield for my car. If Nissan considered it neccessary for the NA motor, seems like an excellent idea on the turbo motor. I'm still waiting on my clutch in order to do my motor trans swap Tony, but I'll still send you some digi photos. Quote Link to comment Share on other sites More sharing options...
