front brake pad issue 280zx
So I got new raybestos brake pads for the front and every thing is the same as the old ones but on the front outer brake pads it has a hump on it which prevents me from using the little nissan brake shim thing on it, BUT the hump fits perfectly in the recess of the caliper, is it safe to use the brakes with out that brake shim ?
Is That Goo like grease or soemthing ? I will probably end up putting the shim on the other side so i don't have pieces lying around.
EDIT: I ended up not using the shim as it would not fit on either side with out modification so I used some brake grease stuff on them. and for some reason the pads were bright red, makes me want to get my calipers powdercoated red.
