Need Manual Transmission's torque specs (think about a 502 Big Block)
cyrus
Did a little searching for OD trans and found:
T56 -Great trans but no scattershields available... this would be my first choice
TKO -Torque specs needed?
ZF- Bad shifter location/cost
Richmond 6 Speed -Expensive!!! Torque specs needed?
Any got info about these?
The TKO 600 is rated at 600ft/lbs. The T56 is rated at about 460ft/lbs IIRC...the tremec site is down so I can't verify that. I think the TKO 600 is the strongest syncro box available right now. Richmond can't touch the TKO600 torque rating I don't think.
