it's idling!
bryan01
good luck, one of the difficult parts for me was getting a good rpm signal for the squirt that didn't interfere with the stock ecu. coil on plugs are fun ...
but good luck, i used the defaults, and common sense when putting in the constants, and i used the ve map that was in there already (i bought it from a friend, it was on a boosted saturn if you can believe that). once i had it hooked up it started first crank. before the squirt i had to hit the gas a lil to get it to fire ... not anymore! ... perfectly smooth idle ... mmmm time to clean up the garage a lil ... i've been working so long w/o a break it's pretty bad down there ...
